EBMetalworks
- Jan 15, 2022
First post. Just bought SB engine lathe. Ser num 7702 TK X14. I have 1ph power in my shop and obviously need 3ph to run the machine. Thoughts/recommendations on phase converter vs VFD?
I posted the serial num in my first post.
Hello. My South Bend is a Heavy 10. I’m not able to identify South Bends by serial number so I’m not sure which one you have, but I’ll show you what I’ve done.
My little South Bend has been with me for a long time. It started out as a 3-phase, 1 hp running off a whole-shop 10 hp rotary phase converter. It has also run as a 1 hp, 3-phase and a 1 hp VFD. Its current configuration is 2 hp Toshiba motor, 2 hp Lenze VFD.
I run it from a low of 20 hz to a high of 110 hz. I’ll show you come pictures of the belt configuration I use. It pretty much stays in this configuration because it offers the most belt traction. There are also a couple of pictures of maximum and minimum rpm in that run position. The lathe has way more power at any rpm than it has rigidity or belt traction.
Bottom line for me is if you are powering many machines, the rotary converter is better. If you are just powering this one machine, VFD is better. I really like variable speed. I hope this helps some.
I want to know more about your carriage lock/stop/indicator holder! That looks super functional. I would like to have this on my machine.
Another approach to the idea, a few pieces of aluminum scrap and a surplus 1" travel indicator:
Thank you all for the info. Very helpful. It is a 14 1/2.
Notice
