WANTED: SouthBend Fourteen Reeves pulley component
manofsteel
Oct 9, 2007
MI
I have a SB Fourteen and am restoring the Reeves drive. When I pushed out the sleeve that attaches to the motor, the pulley cracked due to displaced metal from the pin and screw. I have contacted Speed Selector and they could not assist unless I bought the whole assembly. I have a machine shop that I work with and will contact them in the morning. If anybody has one from a spare machine or converted machine, I would appreciate it. Information on who has one would also be beneficial. I really only need the one side of the pulley, so if someone has a partially broken drive, that would work fine. Thanks in advance
Dave
Pulley model 409-400
9" in diameter
Bore is approx. 1.8"
I looked on eBay and must have missed it. I will look again.
I am having a welding shop look at it today to see what it would take to make it serviceable. It is some sort of cast AL.
Thanks for the replies
Dave
9" in diameter
I have what you need.
Send me an email.
Ted
[email protected]
Guys (and gals),
I TIG welded the pulley and a shop machined it down and balanced it for $25. I appreciate all the information. You gave me several great back up plans if Plan A went awry. It welded pretty easy (and I'm not a welder), I just had to go slow, cleaned it really well, and made sure I had plenty of shielding gas flow. Thanks again
Dave
