Wanted tail stock for 14.5" south bend lathe
Results 1 to 9 of 9
    Feb 2018
    Illinois
    5
    Default Wanted tail stock for 14.5" south bend lathe
    KEY IS DAMAGED. DO NOT KNOW HOW TO GET IT OUT.
    [email protected]
    Sep 2014
    Arizona
    805
    572
    265
    Quote Originally Posted by DUANE FH View Post
    [email protected]
    If itís like my 16Ē, itís soft metal and has a press fit from the bottom side of the casting. Drive it through from the outside and it will fall out of the quill bore.
    Once itís out you can reshape it and reinstall.
    Feb 2018
    Illinois
    5
    Quote Originally Posted by thomasutley View Post
    if itís like my 16Ē, itís soft metal and has a press fit from the bottom side of the casting. Drive it through from the outside and it will fall out of the quill bore.
    set screw on underside was broken. Drilled it out.tried to punch out key from there ,no luck
    Sep 2010
    moscow,ohio
    5,906
    579
    1889
    Pretty sure that key is at about a 45 degree angle, so if you try to drive it keep that in mind.
    Sep 2014
    Arizona
    805
    572
    265
    Before I paid for a new tailstock, Iíd pay for a bigger hammer.
    As Iwananew10k says above, itís on an angle so drive accordingly. It will come out. Might need to add some heat to break the schmoo bond loose.
    Sep 2010
    moscow,ohio
    5,906
    579
    1889
    Ya, IIRC it's really a round pin
    Nov 2017
    Illinois
    152
    Post a couple pictures of what you're trying to do or get out?
    Feb 2018
    Illinois
    5
    got it thank you al
  9. Likes thomasutley liked this post
  10. #9
    Sep 2014
    Arizona
    805
    572
    265
    got it thank you al
    Ted may have more NOS tailstock quills for your machine, although parts for a 14.5 are rarer. The new quill made a night and day difference on my 16" without any work to address wear inside the TS bore yet.
    I'm planning to bore the old quill out for occasional use with MT4 drills. I just need to get more comfortable boring with the taper attachment before I take it on.
