What did I just buy? 9" Model A?
Likes Likes:  0
Results 1 to 19 of 19
    Nov 2019
    7
    Default What did I just buy? 9" Model A?
    I've always wanted a lathe and just came across this cabinet model for $400 and its now in my shop. Holy cow its heavy, it took 4 big guys to move it. I've searched this site and more for more info on the model number to no avail, but did find some pics of a 1959 that look pretty close. The motor needs some wiring work and one tooth is broken, but most of it is intact. It has a 4 jaw and quick change that came with it.
    I think I see this in the name plate (its unfortunate your admins limit pic sizes to 19K...):
    9 Inch Model A
    Catalog # 8447N ( or possibly 3447N, hard to read)
    Bed Length 3 1/2
    High res pic of name plate:
    iCloud
    Any help identifying what year it is, a user manual, parts list, etc would be helpful. While I appreciate the total restorations I've drooled over on this site, I just want to get this one functioning reliably. I have a 1921 Model T, and some parts for restoring this car are just not available, hence my need!
    Jeff
    Hi res:
    iCloud
    iCloud
    broken tooth iCloud
    dd1a2f5d-f818-49d2-99c0-1e4961c2a398.jpg2babbc4d-f387-44c0-92f0-5a09830a1070.jpgd36d0b2a-2745-47fd-975c-87d187738e2e.jpg34f6199f-464f-4151-853c-8e983d0060b1.jpg
    Nov 2014
    73
    37
    9
    Year?
    We need the serial # stamped in the bed, top right.
    Manual?
    HTRAL (how to run a lathe) by SB - Mr Noder usually pops in with a link to
    a digital copy. I think I've see it a couple times in the last month. Search HTRAL
    Get it opperational?
    At the least I would re-felt it with a kit from illion. $ well spent and for $400
    you made out like a bandit.
    lsneon
    Nov 2019
    7
    Ok, I finally found it under a film of dust and oil.
    146142
    JAN
    On the other bed it says UB 101.
    Ok, so it's a 1943 according to the sn db. I found the doc you referred to
    https://www.pdf-archive.com/2017/02/...lathe-1966.pdf
    I found a rebuild kit on eBay, just not sure if it's the right one for mine although it looks universal...
    South Bend Lathe 9" Model A - Rebuild Parts Kit | eBay
    Also is there now a limit on picture size for newbies? I see others posting high quality pics but I can't seem to...
    Jeff
    Feb 2015
    Florida
    451
    86
    It's a 344-ZN 9" Model A with underneath motor drive.
    From the 1943 catalog.
    Nov 2014
    73
    37
    9
    The 146 would have caused me to guess mid 45. I have a 167 and the SB card says Dec 45. The JAN stands for Joint Army Navy.
    While you're shopping, someone sells a 4 pt kit of all the correct oils.
    I make it a policy to lube the spindle every time I turn it on and everywhere else on a pretty regular basis. Be safe
    lsneon
    Nov 2019
    7
    Quote Originally Posted by SLK001 View Post
    Nice. Ok, good news - after spending all day in my shop, I replaced all the wiring, lubed everything, tore apart the apron and cleaned it, and it all works. Forwards and backwards.
    My vocabulary isn’t there yet but the threaded twist bar that is perpendicular to the bed that adjusts that part of the platform throw needs to be replaced. Someone messed up the threads and bolt at the end. It works for now, but I’ll want to replace that at some point.
    It desperately needs new belts. Both of them. Is there a good source for these?
    I ordered a couple of the recommended books from Amazon as well. This is exciting!
    Jeff
    Apr 2009
    CA USA
    93
    10
    is the compound a large dial like the cross slide ?
    animal
    Nov 2019
    7
    I wish I understood your question so I could intelligently answer it. If you can explain a bit more that would help. This is my first lathe. Pictures are worth a thousand words... the arrow points at the part I need to replace. It's about a foot long, threaded.
    jeff
    Oct 2004
    Iowa
    3,186
    73
    425
    Jazz... what we need to do, is find a PM member who's near enough to you to pay a visit, look it over close, and point out all the details, so you know what you're looking at, and what all the functions are, then help you set it up for some basic tool positioning and cutting operations.
    Where in Californica are you??
    Oct 2015
    Virginia
    569
    19
    132
    Quote Originally Posted by Jazzmonger View Post
    jeff
    That is the crossfeed screw assembly.
  11. #11
    Nov 2019
    7
    I'm in Santa Rosa.
    Where can I get belts for it?
    Jeff
  12. #12
    Oct 2015
    Virginia
    569
    19
    132
    I'm in Santa Rosa.
    Jeff
    A lawn mower shop would probably have the V belt. What is it, a little 4L?
    Search ebay for "south bend flat belt" and find the seller ValadiusGroup. I've bought many belts from them and they always cut them accurately and ship them quickly.
    Click the following link:
    South Bend or Atlas Lathe flat drive belt custom cut | eBay
  13. #13
    Sep 2015
    Florida
    627
    90
    Cross-feed dial is not original. Looks like a Clausing, perhaps but picture is too small to tell.
    There is no compound slide...don't know what's on top...looks like a flat plate with gib screws to me for some unknown purpose.
    Can you take a few pics of the "saddle"- just like the name, that's the main part on the bed that cranks from end to end with the large handwheel on front.
  14. #14
    Apr 2009
    CA USA
    93
    10
    I get my bents made by these guys
    Industrial Rubber Products | California | Nevada | CIR
    animal
  15. #15
    Nov 2019
    7
    Here's a better pic of that area. The compound is there as is a quick change. I just put them on.
    Saddle Area
  16. #16
    Jun 2012
    Two Rivers, Wi.
    84
    The compound slide looks like it has a plate for mounting a (SB?) milling attachment. I use an automotive serpentine A.C. belt inside out for the primary motor drive belt, and a el-cheapo harbor fright link type V -belt to get around the spindle pulleys without disassembling the headstock.
    I also have my 9A mounted on an ex high school light 10 model cabinet. May still have the under cabinet drive inside. Not sure if I removed it or not. The 9A was a tool room bench top 36" model with an exposed rear mounted drive. Any 10" drive parts are up for grabs. Ill take a look tomorrow if anyone is interested. EMAIL me directly as I dont get over here too often. Bill at [email protected]
  17. #17
    Sep 2015
    Florida
    627
    90
    You may have already realized this, the adapted cross-feed dial is diameter read- and the "small dial" factory compound is direct read. Not sure I'd want a mix of both on one machine, but that's me...
    I would check to be sure the large dial doesn't interfere with compound operation when it's perpendicular to the bed, or even at the common 29 degree threading angle, over full length of travel. Looks to me like it may not clear the cross slide dial.
  18. #18
    Sep 2004
    NH
    1,137
    90
    The v-belt should be easy enough from your local auto parts and the flat belt can be sourced here;
    Any size flat drive belts by Al Bino Industrial Belting | Machine belts supplier
  19. #19
    Nov 2019
    7
    I got a new belt installed and just rebuilt the apron. Huge improvement. Power crossfeed? I had no idea! The gearbox rebuild will happen is weekend. Tubalcain’s videos are amazing. Highly recommended.
    Jeff
