Wiring motor/switch help...Please - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Dec 2015
    24
    here are two schematic drawings of a single phase dual voltage ,capacitor start motor with centrifugal switch . both drawing's are the same motor ( though id give you two versions of it )your motor is a variation of this motor. This should help you in identifying the motor windings ,so that you can arrange them how ever you need to . I would suggest that you use analog or digital meter ( Simpson 260 //or a fluke multi meter or similar ) both main motor winding sets 1 &2 ,3 &4 should ohm the same resistance ,the start winding will ohm significantly higher than the run winding . note or tag leads after ohming ( I think you'll find the existing color code ( see previous pic ) to be NEMA standards . img_e4319.jpgimg_e4317.jpg
  2. Likes SBLatheman liked this post
  3. #22
    Jul 2008
    South Bend, In
    2,616
    163
    245
    Thumbs up
    Quote Originally Posted by kitno455 View Post
    Ok, Ted said he was game to try, so here goes- All we really are doing is switching everything on both sides of the terminal board between terminals 3 and 4, so the cent switch is at the star point.
    1. on the back of the board, switch the locations of the yellow and orange wires.
    2. on the front of the board, move the white wire with the ring terminal to T4.
    3. on the front of the board, move the red wire to T5.
    4. on the front of the board, ensure the line-in wires from the switch are on T1 and T3.
    Everything else should be as my earlier drawing.
    Oh, and i'd put a couple big permanent marker 'X' marks over the motor wiring diagrams
    allan
    Eureka ! ! That worked
    Thank you very much, Allan, you certainly know what you are talking about
    Thanks again,
    Ted
  4. #23
    Jul 2010
    Virginia, USA
    3,465
    87
    642
    Glad to help. I'm fond of puzzles
    allan
  5. #24
    Virginia
    27,713
    7561
    8626
    allan
    LOL! May I rcommend, then... purchase of a vintage top of the line "Monroematic" motor-driven electromechanical "desk" calculator?
    Needs a fair stout "desk" under it, but should keep you out of pubs and brothels for easily a full week, if not a whole month!
    BTDTGTTS!
  6. #25
    Jul 2008
    South Bend, In
    2,616
    163
    245
    allan
    I installed the motor and all the wiring on the machine today. Smooth and quiet
    ...but, as luck would have it, forward/reverse is backwards
    I assume I need to switch the red and black wires at the motor...? Since we modified the wiring, I don’t want to assume
    Thanks for your help,
    Ted
  7. #26
    Jul 2010
    Virginia, USA
    3,465
    87
    642
    yes, swap red and black wires.
    allan
  8. Likes SBLatheman liked this post
