Next week I bring home a new to me lathe that has a 7.5 hp 3 phase motor. My garage shop power is limited to a 240 volt / 40 amp circuit (unused dryer outlet) so I plan to run a VFD to supply power to the machine. I have two questions:
(1) Can I run a 10 hp VFD to power the 7.5 hp motor?
In reading other posts, it appears that the ideal setup would be to run a VFD that’s 2x the rated motor hp. My concern is that if I did that I’d pull more amps than the 40 amp circuit has available. Is it viable to run this motor on a 10 hp VFD without tripping my breaker repeatedly? I don’t plan on machining very heavy loads that would strain the motor. I’ve considered replacing the motor with a 5 hp alternative but I’d rather not buy a new motor if I can avoid it.
(2) Should I setup VFD just as power source or tie in control panel buttons?
Can I use the VFD just as a power source or do I need to rewire the control panel relays / switches for power on/off, jog, forward/backward & e-stop? I don’t plan on using the VFD for variable motor speed control so it seems easier to use it only as a power source and rely on the lathes existing wiring to handle all the usual features.
This will be my first VFD installation so I’m new to the whole configuration options.
