John.t.little1
- Oct 10, 2014
- St. Augustine, FL
Hey guys so after reading the rpc build thread I am still a little confused. I have a 10hp idler and I need it to power a 7.5hp lathe and 2hp mill. I couldn't find a 15hp so I'll use one at a time for now. I have 9 caps 8 of them are 50uf 370vac 50/60HZ the other is 60uf 7.5uf 440vac 50/60Hz I also have a single pole relay 3100-15Q108 is it's part number. I have a 40amp disconnect I plan on running as the on of for the rpc than out of the rpc I planned to go to a non fused disconnect then to two fused disconnects one for each machine. What amp breaker should I use from the main panel? What amp disconnects should I use for the machines? Should I use a push button start instead of a 40amp disconnect? Here are pictures
Idler
Lathe
Mill
Caps
Relay
Idler
Lathe
Mill
Caps
Relay
