110V 1PH Input to 220V 3PH Output for 3HP Motor - Is there such a thing
Shootr
Jul 8, 2021
Hello all,
I have a couple Nord 220V 3PH 3HP motors from surplus. I don't have access to 220/240V 3PH at my house, but if it's possible to run them somehow off a 110V 1PH 30A circuit I could use one for a belt grinder I want to build.
The circuit was for an RV hookup - I use it for my welder now.
All my googling seems to indicate I can't get there from here. I figured I would check in with you folks and see if there is a way to do it.
I appreciate you letting me come in and ask my silly question.
Hello all,
USE an 120V r1ph input VFD
OR: use an 120V to 240V transformer of sufficient KVA rating and run a RPC
A 3 HP motor at 115V 1 ph would draw 34A. You have 30.
Conversion to 3 phase will have some losses, and also some extra current. You cannot supply it via that 30A circuit.
Hello all,
First, upgrade the branch circuit from 120-only to 120/240. There are no good reasons to NOT do. Avoiding that simplcity just wastes more money than "JFDI"..
Second, either build or acquire an RPC. For all your combined 3-P loads. No modification to the loads ordinarily required.
ELSE BUY a VFD. For each 3-Phase motor. Modification to load-side switching and protective device arrangements will USUALLY be required.
Hello all,
not cheaply, sell current motors and buy a 240V single phase 3HP. as that large on 110V will be expensive!
