zwco
- Aug 4, 2013
- Midwest USA
Hello all,
I have an older US made furnace, "Hevi Duty" brand, with the most recent patent date being in the 1930's. Data plate says its 115v 2phase 18kw rated to 2000 F. The current wiring ends at the hookups for the heat elements. I imagine the relay and temperature controls would have been installed elsewhere and where left when the furnace was moved.
Anyway, I have single phase 240v in my shop, along with a 3 phase rotary converter for my other machines. I can't find much info on 2 phase or how to go about hooking one up in either 1 or 3 phase arrangements. I was hoping someone here might be familiar with this. It seems like its just 2 115v legs each operating half the elements. There are also the remnants of two separate thermocouples inside, presumably one for each set of elements.
Also, I plan to use a modern SSR and PID to control temperature.
