HOw to wire 12 lead Y(wye/Star) 460 or 230 Delta wiring (9kw/12hp) Cazeneuve HB500
This machine was wired 440 V.
I will be using 220.
My thinking to testing and initial starting the lathe was the following:
1.change the two transformers from 460 V to 230V at the Primary terminals. Looks like Trans1 steps down to 110v or 220v but is wired 110 out for Sec. and Transformer 2 is control stepped down to "0" & "24V".
2. change jumpers on the main lathe motor as depicted on the motor placard from 460 Y to 230 Delta.
So here is where I lost confidence and my question.
The motor placard is stamped Voltage : WYE for 460/ Delta for 230 see attached PDF/jpg for terminal IDs, Internal 12 wire ,6 wires coming from electrical box terminals.
The confusing thing is terminal block on the motor is labeled differently than the ele. schematic given? Or that is my take. See diagram in pic.
Also they are using U1V1W1, X1Y1Z1 and U2 V2 W2 and X2 Y2 Z2 nomenclature on the motor terminal block so that is equally confusing.
There are 6 leads coming into the motor out of the enclosure . I am used to feeding 3 leads L1, L2 And L3 into all my other machines at the motor terminal block?
So why feed 6 leads into the motor terminal block? Again see attached for how it is currently wired which is Y 460V?
There are total 3 motors on this lathe Main motor, Rapids motor and cooling pump.
I did checked the continuity between 12 leads and it is the typical 12 lead wire.
1-4
2-5
3-6
7-10
8-11
9-12
So if it was a STD wired 12 lead motor why are not 10,11,12 JOINED?
Cause for a STD wound it should have been L1-1, L2-2, L3-3 and JOIN 4&7,5&8,6&9 and then 10,11,12?
All my internet searching indicated there are two types of 12 lead wire 3 Phase motor.
I have never heard of or experience with Y start Delta run motors? Never heard of this. So which one do I have and how to tell.
1. "Y" Start: Delta Run (12 Leads) name for this kind of "soft" motor starting is Wye-Delta altho Star-Delta is common.
Speed: Single Phase: 3
Typical Voltage: Dual 230/460
Winding: "Y" Start: "Delta" Run
Special Feature: 12 Leads
To put it simple, you are applying a lower voltage (wye or "Y") across the motor to start it. At some point after the rotor is turning then full voltage is applied (delta) to get to or maintain full speed at load. The lower voltage is partially done to prevent high start currents. These type starters are very common on large air compressors. A wye connection offers approximately 58% less voltage than a delta.
Or option 2:
2 From a blog comment I found this statement :"Or is it a more a standard 9 lead motor with the internal Y brought out as 10,11,12 so it can be connected as a Y or delta?"
Or another concerning comment: "when installed they find the 12 leads where not for dual voltage but as explained above a single voltage connection with starting options,"
Any help would be greatly appreciated.
1-4
2-5
3-6
7-10
8-11
9-12
Or option 2:
