Rob F.
- Aug 5, 2012
- California, Central Coast
I have searched archives and the best I was able to come up with is "it depends"... I am looking at a mechanical press rake with a 15hp 208/416 motor. I have 240 3 phase frome my RPC, actual voltage is usually closer to 246. Question is will my higher voltage work on this motor? Some more modern motors are rated for both 208 and 240 but not this one. Machine is from 40's, not sure if this is original motor, my guess is not.
Obviously I would like to not change the motor but if it needs to be done I just need to add in the cost to swap it.
Thank you in advance
Here is a pic of the motor tag:
