Hi guys. I have a few questions about a design to use an inexpensively purchased Ebay 460v/3ph VFD controlling a 230/460v 3ph regen blower. I only have access to 1ph power here. I'd like to start with the transformer sizing. My 10hp 3ph 230/460v 60hz motor is rated at about 8kVA. My plan (based on research done from this forum) is as follows:
230v/1ph/60hz 30amp circuit --> Unknown transformer 230v/460v 1ph (step-up from 230v to 460v) --> 460 VFD (Japanese 3ph/3ph 20hp) --> 460v 3ph blower motor.
My first question, of which there will likely be many... Do I need to match what the motor is rated for with the transformer at 8kVA, or do I need to look for something in the 20kVA range because I'm doubling the voltage? I'm thinking a standard 10Kva transformer will work. This is the only piece of gear off this circuit. The blower will be used for both vacuuming and blowing small grains up into a tank, some of which could be wet and sticky putting a definite load on the blower. Mostly it will be run at like 50% - 75%. -Above I didn't account for the service factor of 1.15 with the 8kVA statement. I guess I need to.
I'll have some wiring questions after I get all the parts together, but this really looks like such a great way to go, instead of adding in a RFC setup. Love the idea of this design.
