Hi all,
Today I started to build my rotary phase converter, I have to spin it up with a drill but it does generate the other two legs once up and running. When some start caps are in stock I will buy some and use a momentary switch to run it without the drill. Anyway, it’s a 10HP idler, and I’m uk based so it’s being fed a live and neutral. The output of the idler is 240-215-215v, I’ll balance this at a later date. As my machines are 415-440v I bought an 8kva three phase transformer, which steps up the three phase output from the idler from 240v to 440v. When I put the transformer in the 240v three phase output of the converter, the 32amp MCB trips. The transformer must suck up too much current when power flows into it. How do I stand using the transformer as a single phase one, and powering the idler with just the single phase at 440v. I’ve seen others do it this way, but not with a three phase transformer. The transformer has three inputs and a neutral on the one side, and three outputs and a neutral on the other. Would I just connect the 240v live in L1 and the neutral in the neutral terminal, and take it out the other side, or is there more to it than that being a three phase transformer.
