waynes
Cast Iron
- Mar 5, 2011
- Trenton, On
Since I now have two working 460V VFDs and only one transformer to feed them, I went back to the scrap yard today. Found two transformers that I think might work to feed the VFD. Heres a pic of ones wiring diagram and a pic of the other (no wiring info at all).
After some reading on this site about similar attempts, seems the transformer with the wiring diagram can't be fed 240V to the 120V windings as it would go into saturation.
The other is apparently 1 to 1, just over 6 inches square, and is wound with .150" square copper for both windings. It was with some Gettys N350 servo drives - but I don't know what specifically it was used for (I did bring home the 3 complete drives). The 1:1 was found by feeding 125V into one winding and measuring 125 at the other winding.
I'm thinking this could be wired as an autotransformer to make it a 1:2 transformer. The terminals are just labeled 1,2,3 & 4. So I'm thinking line goes to 1, other line goes to 2 and 3, and the output is from 1 and 4. Is this correct or did I fail with my reading comprehension?
Actually I don't know if the junction between the coils should be 2/3 or 2/4. What happens if it's wrong? I'm thinking the output would then be near Zero between 1 and 4???
Wayne
Wayne
