Thanks for the replies. Been a little tied up the last few days. After some time on the phone with Fanuc, we got down to two possible culprits. The servo motors (which are AC) and the servo amplifier board. I was able to get an electrician to come by this morning with a megger to test the motors. I got him test them all while I had him. The servo in question tested out at 70 mega-ohms. The X and Z servos didn’t test a whole lot better (200 and 500 mega-ohms). It appears I am in for some repairs if I want to continue running this machine.
? If your electrician used a 500 or 1000V megger. who told you those values was a issue?
None of those values are even worrying. Not that your motor might not benefit from a proper touchup.
Alot of meggers wont even measure over 550 Megaohm.
If you dont have the original test values for your motor you have nothing to compare to, and even if they are identical such variation is quite normal.
If your really think changing the servo motor because it 'only' has 70 Megaohm resistance on a megger test from a 500/1000 Volts megger will help good luck.
If the test showed somewhere in the the vincinity of 1 megaohm you could start to be worried about it.
For general electircal equipment 230/400V over here the requirement is minimum 1 Megaohm. Even if it's a 400V 1200 amp VFD driven motor. And measuring 70 Megaohm on a motor of that size even is quite normal.
So anyone that told you, that you should worry about megger tests ranging in several hundred megaohms should really not give advice to begin with.
If it was your electrician next time ask for one with some experience from automation/industry and you might get someone somewhat knowledgeable for the application.
Did your electrician also check your motor windings resistance separately and compare them?
Something witch should be mandatory.
That will also give you a easy indication on its well being.
As for the power grid in Europe here is 230 or 400 volt 50 hz, and all the equipment per specs has a max +- 10% voltage variation, according to CE etc, same as the power supply companies use.
And yes a new transformer nearby has at times caused issues for equipment because of boosted voltages, and phase issues.
