.25 mfd capacitor
rj1939
Stainless
Jan 31, 2008
southern il
Having trouble getting a .25 mfd dc capacitor to replicate a Cincinnati schematic...................it goes across the dc leads coming off the rectifier bridge, to convert 120 ac into dc.
Any suggestions
More information. Voltage ratings, type, continuous current/power rating, original manufacturer...
if 25,000uF is not available, why not 30,000 or 40,000, etc.?
DigiKey
In current terms 0.25 mFd = 0.25 uF, in year past it was milliFarad which is an order of magnitude greater, I am assuming you are looking for a standard film or an RC snubber which are more common. Maybe a copy of the schematic and some more information as to a power supply for what?
RC Snubber
https://www.mouser.com/ProductDetai...EpiMZZMsh%2B1woXyUXj9yQU%2Bz0G7ZzAsfvWMH8VFY=
https://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/254M06QD100?qs=kwWuCeDmeqEwNMM%2BE2N9GQ==
Film capacitor
https://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/418P25496MB3?qs=M5E3J2MuaV4mvv9V91NTMQ==
mfd = microfarad = 1 e -6 farad
mmfd = picofarad = 1 e -12 farad
kc = kHz = 1 e3 sec*-1
mc = MHz = 1 e6 sec*-1
Old school stuff.
What you describe is just basic power supply.
Value seems to small for ripple filtering but may be for noise filtering.
Either way, what matters more is voltage rating, can be higher but not less.
Actual value can be anything close.
For ripple filter bigger usually better upto a point as too large may cause current limit issue on rectifier.
Sent from my SM-G781V using Tapatalk
0.25mFd. Not 25mFd. Whoops.
0.25 millifarad = 250 microfarad. :dunce:
Then again, what 'brilliant' engineer came up with the idea of expressing 250uF as .25mFd? That expression defies convention.
Frankly using 'mFd' at all is and was a terrible idea from the very start of the electronic age. Just do as every sane person & manufacturer does and skip over the milifarad range of notation entirely unless spelling it out completely. pF, uF, F. That's all you'll ever need.
250uF across + and - of a bridge rectifier is a basic electrolytic filter cap. Available anywhere.
If capitalised as MFD, it almost always refers to microfarads. I think this may date from periods when all text was capitals and things were not very standard, plus capacitors in the milifarads were simply impractical.
The 'modern' symbol for a Farad is simply 'F' - no d.
Am trying to upload a diagram, in the file it says 10k, when I try to upload it, it says it is 9.9M........................
Looks like they are being used for suppression of spikes from the magnetic coils. Yeah, 600V seems fine, won't likely get an overvoltage with that if they have selected the capacitance correctly.
OK...........how do you read the capacity in modern terminology?
Why couldn't I go oversize on capacitor...........if it is more expedient from a cost/supply standpoint?
Snubbers. The clutch & brake generate a sharp back-spike similar to breaker-points to an ignition coil for firing a sparking plug when the power to their electromagnetic actuating coils is de-energized.
These function to pass the fastest-rising portion of that spike to protect the control contacts and extend their life. Radiated electrical "noise" of said spike is also reduced, so it is less of a rude neighbour to any nearby sensitive electronics goods.
Especially so as they're dc-operated. Also note the 600 volt rating.
In modern times this would be a snubber diode and a MOV varistor.
Seems like an old fashioned automotive condenser would be a workable substitute
As shown, your diagram depicts a 0.25uF snubber capacitor.
A larger substitution will work just fine as long as it's intended for that use. (Snubbers are designed to have low inductance to perform better at their unique job - going from zero to 'a bunch' of amps in a hurry.)
Catching diodes are pretty common in this application - sized (prv and current rating) correctly they do a good job of taking the ringdown away fast.
Capacitors are very reliable, and are effective. Diodes are tough, but not as reliable. And they have some other issues as well
The size is more critical than one might think.... you do not want to end up with an RCL circuit that "rings" and keeps sparking on the contacts. Ideally you get "one and done" on transients, with the "one" blunted severely by the capacitor.
