SufernTlmkr
- Nov 22, 2019
So after purchasing my lathe I needed to get a phase converter. So I purchased the Control through North American Phase Converters out of New Berlin Wisconsin. The Motor I have is a WEG brand 7.5 HP with 12 wire leads. Which I have later found out may or may not be aWye start zero run motor? I have everything wired up but the on the 3rd generated leg is way too low. From L1 to L2 242 volts. L1 to L3 239 Volts and L2 to L3 is 127 Volts. DO I have a bad run capaciter? Is there something wrong with the motor? How do you tell if it's up to speed?
