mjk
Titanium
- Oct 20, 2005
- Wilmington DE USA
I'm not a motor wiz but I did build a rotary phase converter years ago that had many good comments on this forum and it functioned very well until I was in a shop with 3 phase delivered.
Last year I bought a cold saw blade sharpener off the bay from a guy who been using it for years (30+?)....
He was retiring and when it was listed it was mentioned it needed some work.
Being the only bidder I won it.
It turned out a couple wires were loose and a capacitor was toast.
This summers project is to clean up the machine, rewire and re-switch with components that are available if need be.
Everything looks to be unobtanium.
So in making a drawing of the existing wiring diagram, it looked surprisingly like what I remembered of a phase converter start circuit.
Upon removing the motor connections cap sure enough a delta and wye diagram.
They are using a start capacitor with a momentary manual switch to get it going and a run capacitor to "generate"
The sharpener motor is probably 1/2 hp and the load minimal.
Question
Is this or was this normal way of building industrial machinery when single phase is required?
This was not a retrofit, it was delivered as a 110v single phase machine
motor plate pic
Question
motor plate pic
