3 phase wiring question
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
    Jan 2018
    Connecticut
    22
    Default 3 phase wiring question
    I made a power cable with a plug on one end that plugs into a 220 volt dryer outlet. What are the three wires, at the other end of the cable, connected to in my 3 phase, wye wound, 9 lead motor. It has wires 1 & 7 connected to wire L1, 2 & 8 connected to L2, 3 & 9 connected to L3 and 4,5,6 wired together. Thanks, henrylr
    Feb 2006
    Indiana
    13,871
    797
    4638
    Quote Originally Posted by henrylr View Post
    Dryer outlets are not a source of three phase.
    Larry
  3. Likes digger doug, Bobw, 4GSR, eKretz, N/A and 5 others liked this post
    Jul 2006
    Hillsboro, New Hampshire
    12,950
    2938
    8932
    Quote Originally Posted by L Vanice View Post
    Larry
    I think the OP should consult a qualified electrician before he hurts himself.
  5. Likes BT Fabrication, Yan Wo, duckfarmer27 liked this post
  6. #4
    Aug 2012
    California, Central Coast
    5,213
    2381
    2148
    Depending on the dryer outlet it has either 2 hot leads and a ground or two hot leads and a ground and a neutral. Either way the two hots are most likely 240v single phase.
    It might run your motor if you can spin it over while you add the single phase power but it will have less power. ( feed the single phase to two of the three phases of same voltage on motor, one motor lead not connected)
    Best to use it to power a RPC to make you the needed 3 phase for the motor.
  7. #5
    Oct 2005
    21,576
    Where's the fun in that ?
  8. Likes Bobw liked this post
  9. #6
    Feb 2006
    Republic of Texas
    2,901
    [QUOTE=henrylr;3741263....... What are the three wires, at the other end of the cable, connected to in my 3 phase, wye wound, 9 lead motor. It has wires 1 & 7 connected to wire L1, 2 & 8 connected to L2, 3 & 9 connected to L3 and 4,5,6 wired together. Thanks, henrylr[/QUOTE]
    Don't really understand your question, but it appears that the three wires are conductors. No ground or neutral in this setup.
    I have a number of 3 phase machines using this 50 amp rated plug/cable:https://www.acehardware.com/departme...-cords/3835196, 3 hots and a ground.
  10. #7
    Aug 2012
    5,213
    2381
    2148
    Quote Originally Posted by alphonso View Post
    But are your 3 phase machines (that you are using a single phase pigtail on) plugged into a single phase dryer circuit?
    Or did you wire 3 phase power to your outlet?
  11. #8
    Feb 2006
    Republic of Texas
    2,901
    "3 hots and a ground" would imply 3 phase service, so, yes, 3 phase to the outlets.
  12. #9
    Aug 2012
    5,213
    2381
    2148
    Yes, but you are using a single phase outlet for the three phase in your shop where the OP seems to want to plug a 3 phase motor into his existing dryer circuit, which is most likely a standard single phase dryer oulet. Maybe we will get clarification of what he has and what he needs...
  13. #10
    Jul 2006
    12,950
    2938
    8932
    I "think" most of us are going with the current dryer hookup being two hots (normal residential single phase incoming power) and a ground, and the OP is trying to milk 3ph from it.
    Which brings me to the novice farmer trying to hook the milking machine to the bull, and getting similar results to what #1 poster will get...
  14. Likes eKretz liked this post
  15. #11
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    4,048
    109
    972
    reverse 2 wires .
  16. Likes digger doug liked this post
  17. #12
    Jul 2004
    4,048
    109
    972
    and i thought jail was "2 hots 'nd a cot....."
  18. #13
    Sep 2017
    South Carolina
    874
    643
    660
    Quote Originally Posted by tnmgcarbide View Post
    That is true only if you count the 3 hour old grilled cheese sandwich as i of the hots.
  19. Likes tnmgcarbide liked this post
  20. #14
    Nov 2013
    Eastern Massachusetts, USA
    6,969
    5954
    6364
    As others have said, a 220 volt dryer outlet is single phase, not three phase. Normal wiring would be L1, L2, and ground (no neutral). In standard single phase residential service you would have 110 volts from either L1 or L2 to Neutral and 220 volts between L1 and L2. This is because the service is provided by a 220 volt transformer secondary that also has a center tap. The ground is for safety only.
  21. #15
    Guest Guest
    From what I have seen with my own two eyes the electrical profession has a higher percentage of hacks in it than any of the other construction trades. In Cali I fired 3 electricians all licensed and bonded to finish a job myself that wasn't all that complicated and maybe 30 hours work, I was just too busy to want to do it. The house I live in that I am remodeling now has more bad wiring work than you can shake a stick at and I am assuming it all could not be DIY amateur work, as it is obvious 4 wiring jobs to the well failed over the course of 40 years. That was discovered when digging was done by my neighbor and his mini back hoe so I can replace the water and electrical line properly.
  22. #16
    Feb 2004
    peekskill, NY
    26,849
    6172
    In a word, no. Highly unlikely you have polyphase power in your residence. Consult an electrician please.
  23. #17
    Jul 2004
    4,048
    109
    972
    That is true only if you count the 3 hour old grilled cheese sandwich as i of the hots."
    is that what they mean by "cannubial visitations" ?
  24. Likes crazygoat liked this post
  25. #18
    Mar 2006
    Washington
    949
    196
    89
    Quote Originally Posted by Scottl View Post
    He could have a NEMA14-50 dryer receptacle with neutral to explain the 3 non-grounding conductors
  26. #19
    Jul 2004
    4,048
    109
    972
    3 hour old grilled cheese sandwich...................that's what my wife hears...i'm sorry...
  27. #20
    Jan 2014
    Utah
    728
    1900
    358
    I was about to write the same opinion, but with "kills" instead of "hurts."
