3 phase wiring question - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
  1. #41
    Feb 2017
    893
    9
    368
    Quote Originally Posted by Human_Condutor View Post
    Actually guys, I think he is just using a dryer outlet for distribution from his generator....
    not connecting it to his residential supply.
    He STILL should not be using single phase components (dryer outlet) with 3-phase electrical. He should be using 3-phase plugs, wiring, etc.....a 3-phase plug/outlet is $20, why is he messing with a dryer outlet? OP needs help BADLY with electrical expertise, IMHO.
  2. #42
    Oct 2005
    21,576
    That's not what I am reading, you even hi-lighted the word "motor"
  3. #43
    Apr 2021
    Alaska
    I def agree with the unrated/underrated jack, but it unclear if he is attempting to run a three phase motor on split-phase, setting up a RPC, or simply using the outlet as a jack from a generator head.
    I took it as the latter when I fiest read it, but now I'm not sure.
    I landed here because I am investigating RPC construction and use, so... I probably shouldnt have said anything anyway.
  4. #44
    Jul 2006
    Hillsboro, New Hampshire
    12,950
    2938
    8932
    The OP hasn't posted anything since starting this thread.
    Ominous...
  5. #45
    Jun 2001
    St Louis
    19,191
    2361
    3582
    Quote Originally Posted by drcoelho View Post
    I do not disagree.
    But per Code, you can use any plug rated for the usage (volts/amps) which is not used for any other voltage in the "facility". It's legitimate, if not perhaps an ideal solution.
    The 4 pin dryer plug is rated for 250V, and will carry quite a bit of current , so if there are no dryers etc in the facility using the same plug, that's accepted. I won't call it a perfect solution.............
    If it were me, I would prefer to use a 3 phase plug for three phase, and I would at least label each outlet that does not conform to the usual usage with what it provides.
  6. #46
    Sep 2005
    Oakland, CA
    2,969
    555
    941
    The misconceptions I've read in this thread regarding the function and use of a neutral conductor versus a safety ground in a single phase circuit are downright dangerous. A neutral is very much a current carrying conductor. Try disconnecting it and see if anything operates. Nuf said.
  7. Likes Yan Wo, SomeoneSomewhere liked this post
