3 wire Brushed 110vdc motor wiring
Likes Likes:  0
Results 1 to 9 of 9
    Oct 2020
    Oregon
    10
    Default 3 wire Brushed 110vdc motor wiring
    Forgive me I'm spending hours on google trying to understand this motor and how to control it. I got it out of a large treadmill it is a 3hp 110vDC brushed motor with 3 wires. I want to use it to upgrade a mini mill spindle motor if I can. Do I use a SCR phase converter? and with that do I run 110vAC into it to run this DC motor? Or do I have it all wrong.
    Can you recommend a good controller to use
    I am perfectly comfortable doing electrical work on house and other machines but don't have much experience with large DC motors like this.
    Oct 2020
    Oregon
    10
    Im also confused because the motor has 3 wires black, yellow, and red
    Jun 2001
    St Louis
    18,703
    2140
    3329
    Looks as if the third wire is just a ground. Apparently a green/yellow wire, right? So the others are + and - and you know what to do with them.
    wiring-diagram-smooth0001
    Oct 2020
    Oregon
    10
    Quote Originally Posted by JST View Post
    Im not sure, it is solid yellow and goes to a terminal labeled BW on the original controller. Ive been trying to find the actual wiring diagram for this treadmill but havn't found it yet. It was a CYBEX 445T treadmill. I also need the diagram if I want to reuse the orignal controller board and figure out which wires to short to turn it on and which wires to use for the potentiometer
    Oct 2020
    Oregon
    10
    the yellow wire has NO continuity to the motor frame so I dont think it is a ground is it?
    Jun 2001
    St Louis
    18,703
    2140
    3329
    Well, then it is the speed readout from connection 14 maybe.... it would surprise me if that was a single wire, though.
    What DOES that wire connect to continuity-wise?
    Oct 2020
    Oregon
    10
    OK I figured it out I finally found the right schematic and it turns out that yellow wire is just a brushes monitoring wire so the machine could tell you when the brushes needed changed. SO I can don't need to hook that one up
    Oct 2017
    760
    211
    229
    Quote Originally Posted by 57buick View Post
    Treadmill motors I've seen have the overtemp sensor located on the brushes. It could be that.
    Oct 2020
    Oregon
    10
    well the manual I found specifically says it is for monitoring the brushes and will alert you 100 hours before it shuts the machine down that the brushes are needing changed soon
