DanMc77
- Aug 23, 2017
- Holden, MA
Hello! I recently picked up a South Bend lathe and got a Teco VFD to get 3 phase power.
I need to figure out how I'm going to mount this VFD on the lathe. I have two options, as I see it:
Option 1. Mount the VFD down on the back of the base in a good sealed enclosure, then bring up wires to the top for controls, Stop/Fwd/Rev/Speed.
In the case of the enclosure, I'm trying to find a good reasonably priced enclosure. I have concerns about chips making their way into the enclosure down below since there will need to be ventilation for heat dissipation, which means openings for airflow. The older enclosure with the magnetic relays had a good number of chips in it, and there was evidence of some of those chips occasionally creating some minor fireworks. I have no idea how chips got in there as the old steel enclosure had a good seal.
Option 2. Mount the VFD higher up in the back, above the chuck and to the left. This seems to be a bit more appealing since chips are less likely to end up over there and access to the VFD panel would be right there at eye level. Again, an enclosure would be prudent and in this case, an easily opened door would be good.
In both of these options, I need a good enclosure for the VFD, which is 8"x5" x 6" deep, a Teco N3-202-CS-U. Anybody have any recommendations on a cost effective enclosure for this? One with a clear door seems appealing for a low volume occasional use application like mine.
