40HP RPC bearing size
claya
Cast Iron
Aug 6, 2006
california
Anyone know what bearing size the AD-40 RPC (American Rotary) uses?
I would like to have the bearings in hand before tearing down the motor.
AR only provides the part #, not the actual bearing #.
Tearing down the motor is no big deal. Done it many times, too many. You're going to have to do it anyway.
Procedure:
1. Unbolt the two end bell covers.
2. Use a little heat on the covers to make the bearing hole larger.
3. Remove covers one at a time.
You think that is the worst part right? Wrong.
You have to remove the original bearings off the rotor. I always have to devise a fixture for that and either use some heat or pressing a op.
Ya. Looked there also.
AR wants $400/pair. That seem right for that motor size?
Sent from my SM-G975U using Tapatalk
Go call Motion Industries to see what AR's profit margin is...
I would part the case and flush the original bearings with acetone or lacquer thinner. Then inject the grease. Can eliminate a costly guess so.
If they are rubber sealed I've heard that a rubber side can be popped off and then pushed back on after a cleaning. Have not done that myself.
I replace my motor bearings with totally sealed ones. Reason is less atmospheric/particle contamination.
