40HP RPC bearing size
Likes Likes:  0
Results 1 to 6 of 6
    Aug 2006
    california
    287
    28
    Default 40HP RPC bearing size
    Anyone know what bearing size the AD-40 RPC (American Rotary) uses?
    I would like to have the bearings in hand before tearing down the motor.
    AR only provides the part #, not the actual bearing #.
    Aug 2014
    bainbridge island
    1,513
    328
    387
    sometimes its on the motor nameplate.
    Aug 2006
    california
    287
    28
    Quote Originally Posted by johansen View Post
    Ya. Looked there also.
    AR wants $400/pair. That seem right for that motor size?
    Sent from my SM-G975U using Tapatalk
    Jul 2004
    Houston, TX USA
    32,578
    Frame size? Maybe 324T? Out put shaft is 2.125 - which means the bearing bore is somewhat larger than 2.125.
    Here is an example WITH bearing sizes - for 324T.
    Not necessarily YOUR bearing sizes
    https://www.alliedelec.com/m/d/51314...4c65b91c1f.pdf
    have fun - you probably know you can look in the electrical section of Machinery's Handbook and find out what your frame size is by measuring the motor
    Mar 2009
    6,704
    131
    1284
    Tearing down the motor is no big deal. Done it many times, too many. You're going to have to do it anyway.
    Procedure:
    1. Unbolt the two end bell covers.
    2. Use a little heat on the covers to make the bearing hole larger.
    3. Remove covers one at a time.
    You think that is the worst part right? Wrong.
    You have to remove the original bearings off the rotor. I always have to devise a fixture for that and either use some heat or pressing a op.
    Mar 2009
    6,704
    131
    1284
    Quote Originally Posted by claya View Post
    Go call Motion Industries to see what AR's profit margin is...
    I would part the case and flush the original bearings with acetone or lacquer thinner. Then inject the grease. Can eliminate a costly guess so.
    If they are rubber sealed I've heard that a rubber side can be popped off and then pushed back on after a cleaning. Have not done that myself.
    I replace my motor bearings with totally sealed ones. Reason is less atmospheric/particle contamination.
