lounsbmw
- Sep 30, 2008
- Greenwood, NY
I am new to this forum and have read a lot of threads looking for solutions to an issue I am having with a phase converter. I obtained a 7.5hp rotary phase converter(autostart with capacitors, relay, etc.) from a guy who used it in his woodworking shop until he went to a VFD. It was wired in using 220/240 single phase and worked great. There are no tags on the RPC because it was removed to be re-painted and never put back on. The guy told me that it was a Baldor motor. For my shop I have a hoist that was removed from where I work. The hoist is a 440/480 3 Phase only setup. (That's what the diagram/tag inside the cover to the junction box on the hoist says) Along with the hoist from work came an ACME 10KVa general purpose transformer (model T-2-53516-3S). It is a 240 X 480 PRIMARY VOLTS — 120/240 SECONDARY VOLTS — FOUR WINDINGS — 1Ø, 60 Hz. I used this transformer backwards to step up my single phase input voltage to 480. I then re-wired the phase converter motor over to the 440 settings(there were 9 wires coming from inside the motor labeled T1 thru T9) using the following directions that I located on the internet:
For 440V, Leg 1 gets hooked to wire 1, Leg 2 gets hooked to wire 2, Leg 3
gets hooked to wire 3. Wires 4 & 7 are connected, wires 5 & 8 are
connected, and wires 6 & 9 are connected.
I left the capacitors and relay/switch wired the same way they were when wired for 220/240 and connected the single phase inputs to the same place. The way it ended up being wired was the incoming single phase connects to Leg 1 and Leg 2. Leg 3 is where the "third" phase is produced for the output.
The issue I am having is that when I apply power to the RPC it starts turning slowly, the relay in the start circuit connected to Leg 3 opens, disconnecting the start circuit. The motor continues to turn slowly until it kicks of my double 30 amp circuit breaker.
I have done some troubleshooting with a volt meter. In the knife switch box used to apply power to the RPC with the knife switch open(no power to RPC), I get appox. 475 volts on the two terminal lugs where the knife switch makes contact. If I go from each terminal lug separately to the neutral/ground bar in the box, I get approx. 275 on one and approx. 198 on the other. Could this single phase voltage difference on the input legs be the issue or is something wired wrong in the start circuit with the capacitors not starting the motor correctly or just something not wired right? I am sure I missed something in my explanation of the system, so feel free to ask questions and input your theories. Thank you.
