silencerman
- Nov 7, 2011
- Pennsylvania U.S.A.
I just got my electric service installed today. Due to PPL not doing high leg delta anymore my options were 4XXD or Y and 120/208Y. While i hated the idea of it i decided on 120/208 as it was the cheapest to install and i don't have to deal with phantom draw from transformers. The problem is that i have some 480 equipment and a 480 to 240 delta transformer to step up the voltage. The transformer is multi tap and has a tap for 503 on the high side which should give me 430 output when fed with 208. My question is will 430 be an acceptable voltage to run my 480 equipment at or should i look for a better suited transformer ASAP?
