tnrcboatracer
- Aug 7, 2021
I purchased an ACRA mill at auction. Was in service up until the auction at a local shop. I had intended to switch the motor to 230 3ph, but the Yaskawa VFD on the mill is 380-480V input.
My shop is small and i don't foresee needing more than 15-20hp of 3ph power. My current RPC has a 7.5hp idler, and i have several more surplus 3ph motors from 5hp to 25hp. My current thought is to run the RPC at 230V, and put in a step up transformer to get to 460v.
The other option to to replace the VFD on the ACRA with a 3hp 230v input VFD. My thought here is that 380-480 input VFDs are common on surplus equipment, so having 460v 3ph power available in the shop would be a good thing.
My understanding is that the RPC putput is Delta, and i am considering a 15-25 kva transformer to provide the 460v. I find lots of delta-wye 460d-230y transformers, but my thought is that i need a delta-delta, or a true 230d-460y step-up transformer. I don't see where i need the 460v wye configuration in my application, as my machines will run a 380-480 VFD for the motor speed control. The small cnc lathe and mill in my plan will be 230V; so again, no need for the 460y.
Any thoughts or guidance would be greatly appreciated.
Sent from my SM-N920V using Tapatalk
