viragocafe
- Mar 18, 2018
First off before people jump all over me and tell me we need to use a 10 hp motor. I want to state that we have ordered the correct 10hp motor we need with 215t case, power inverter, and magnetic starter.
The situation is we have installed some new equipment that require much more air than our old 220v compressor can keep up with RIGHT NOW. So we are RIGHT NOW adding an extra 120 gallon tank for additional storage capacity, upgrading the pump to one that puts out 43 cfm at 175 psi. Which will require the 10hp motor (220v or 3 phase with inverter) to power it correctly THAT WE ORDERED. But it will be weeks before the correct motor arrives. We do have two 5hp motors from old compressors. Would two 5hp compressor motors be able to power a pump that requires a 10hp motor? THIS IS TEMPORARILY SPEAKING! How would a single 10hp motor power or torque compare to two 5hp motors? Or is two 5hp motors far less or more power than a single 10hp motor? Is there additional information that is require first to determine this like amps, efficiency rating, or some other specifications from the different motors?
Like I have said I am curious if we can run a setup like these two 5hp motors to temporarily run this pump in place of a 10hp motor without completely burning up the 5hp motors? I am not interested in making a mess and destroying these 5hp motors but if we could set this up for a couple weeks and run the system with any level of stability that be great until the correct components arrive here next month. Thanks in advance to anyone who took the time to supply an actual answer or information and not just talk smack.
