Trboatworks
- Oct 23, 2010
- Maryland- USA
I’ve finally got tired of bolting VFD’s on everything and want a rotary.
Primarily furniture type shop- right now I have a big edge sander, a narrow belt sander , hinge borer, and a carbide grinder which need to run.
A upgrade to the dust collector probably and a CNC router might eventually come into shop.
So right now in my one man shop just the 5 hp edge sander with its 1/2 hp oscillating motor running as one time load(I am leaving drives in gear that currently has them).
I can imagine upgrading to dust to 5hp.
So near future two simultaneous 5hp motors.
I called AR and the tech said to go 20 hp ADX.
What say you guys- I am trying to control cash flow just now so 2k out the door on the ADX is a bit much.
Just cobble something together - used 10 hp motor and AR box..
It seems AR get such good reviews that I want to stick with their gear.
I’d like the thing to be as quiet as can be expected.
What has been your experiences- start small and just upgrade as you go or just drop in a larger unit than currently needed.
I guess as I stand I need the ten, 15 is a bit of buffer.
But the AR vs AD or ADX series- do I need the more expensive types?
I have to admit- it would be nice(probably worth it) to just ring AR up and have them ship a unit.
I am sort of worn out with looking around for used gear.
