Ab vfd parameter clarification needed
Likes Likes:  0
Results 1 to 16 of 16
    Upstate NY
    989
    7
    39
    Default Ab vfd parameter clarification needed
    I'm looking for some parameter clarification for an AB 161S-AA 02NPK VFD - Specifically vin the are of current limits and two wire control. If you have some familiarity with this model VFD I can provide additinal detail regarding my questions.
    Rick
    Jul 2008
    Philadelphia
    2,046
    548
    471
    I am not insulting you, or trying to be a smart ass.
    Why not contact the manufacturer / tech support? Or have we moved beyond their realm? Gross example you bought a clothes washer and have configured it now to dry as well. Maytag isn't touching it or giving any help to you.
    Never did get whole story about how I was dropped on my head twice in one day.
    Upstate NY
    989
    7
    39
    Quote Originally Posted by doug8cat View Post
    I did contact rockwell automation - they will not deal with a private individual any more - they need a service contract or a valid company
    Aug 2010
    Tucson, AZ
    276
    8
    65
    This information is spelled out in the manual (see link), rating specifications are also on the VFD labeling. Input output ratings are on page 39 of the manual. Input parameters are outlined on page 33 of the manual, you would need to reprogram input C01 = 00 (FW) Forward and C02 = 01 (RV) Reverse for 2 wire control if this is what you are asking.
    Manual: http://literature.rockwellautomation...m000_-en-p.pdf
    Upstate NY
    989
    7
    39
    I agree it is spelled out but the two parameters you pointed to don't result in a start. C01 is an input so there has to be a corresponding output that that goes through the maintained switch. On other VFD's I have programmed that output was thrugh a common terminal. There is also a paramter value of 31 for the C01 to C05 terminals that determines the source of the start command. I can't get that 31 value to appear on the list. I believe there are a number of interrelated parameters that need to be set.
    Rick
    Nov 2008
    Madera county california usa
    2,610
    21
    674
    We have same controlled with drum switch.
    Modified ins set of contacts to "MAKE" before others and use that as part of STOP loop.
    Another set switched on either way is RUN and last set switched only in reverse is RUN REVERSE.
    Cannot remember which wires but the above labels should get you close.
    Aug 2010
    Tucson, AZ
    276
    8
    65
    You did not clarify what you have tried, so lets go through the other parameters. This is a UK model but the parameters may have been changed, depending on if the default is US or UK changes the parameters.
    Ideally you should do a factory reset to set all the values back to their default settings b85 = 07 for 60Hz if you are in the US.To activate this parameter, set the value and press the Enter Key, then hold the Select, Up, Down, and STOP Keys for 3 seconds, release only the STOP Key until display is blinking, then release all of the keys. When you reset the VFD the default US setting is 3 wire control, C01 =22, C02 = 20, C03=21 with C13 = NC, the UK is 2 wire. If US these all need to be changed for 2 wire control
    Terminal inputs are active through a connection from P24 to the designated input (not L), the inputs can be set for NO or NC and these differ depending on the default set loaded.
    Parameter protection, check that b31 should be 00, if you can't access parameters it may be because of the lock. Make sure none of the terminals C01-C05 are programed for 15 SFT. The default setting for b31 is 01 All parameters locked except PF01 when this input is active
    A01 indicates the frequency source, select 00 for keypad, 01 for O/OI analogue reference
    A02 start command select, should be 01 = control terminal block
    C01 = 00 Run Forward
    C02 = 01 Run Reverse
    C03 = 02 or 06 (JOG). Note the factory US setting is 21 which is 3 wire Stop with C13 set as NC this must be reprogrammed
    C11 - C15 must all be 00 or NO contacts.
    Jun 2001
    St Louis
    18,703
    2140
    3329
    I really SHOULD close this thread for a worthless and meaningless title.
    But I fixed your title because I still could.
    Aug 2004
    2,782
    29
    671
    Quote Originally Posted by Rick_B View Post
    Not true. You only need a TechConnect contract for drives tech support if you want it after normal business hours, M-F 8-5 CST. They will ask you the name of your company, but just give them your name if you are a sole proprietor. They are looking up records to see if you have called before, but it doesn’t really matter, it’s just so they can tell if it’s something ongoing.
    That said, the 160 drives are long obsolete and have not been sold new for well over a decade now. Support for them is waning.
    Upstate NY
    989
    7
    39
    Thanks mksj - that all seems to kae sense. I'll give your recommendatuons a try.
    JST - I appreciate your effort - thanks
    Jraef - appreciate the info. I wasn`t sure what I would be getting into if I gave them a fictious cmpany name
    Rick
  11. #11
    Upstate NY
    989
    7
    39
    mksj - so I decided to follow your instructions exactly starting with the factory reset. When I selected parameter B85 - the only values available to me were 01 - 05. values 06 and 07 were not listed. I had previously programmed C01 for run forward but had not used the P24 terminal. When I switched the wire to P24 the run command worked as expected. So while everything seems to be working as expected I am still very curius why certain parameter values are not available/ Any thoughts?
    Thanks for all of your help
    Rick
  12. #12
    Jun 2001
    St Louis
    18,703
    2140
    3329
    You may have a special version, in which there is non-standard programming.
    Otherwise, there may be a code that must be entered to get further in the parameters. That should be listed in the manual.
  13. #13
    Upstate NY
    989
    7
    39
    Quote Originally Posted by JST View Post
    I suspect you are correct - there is likely some hidden/not obvious paramter path that would allow me access to all of the values. Given that things ar4e working for what I need - I a leanibg to just moving on
    Rick
  14. #14
    Aug 2004
    2,782
    29
    671
    There were 3 different version of the 160 SSC, Series A, B and C. Yours is a B (pre-1998) since you have parameters that start with A or b. In that series there were a LOT of special versions made for OEMs and the "reset to default settings" was restricted by the OEMs via custom firmware programming in b85. Sounds like that's what you have and there is no way to "jail break" it that I am aware of.
  15. #15
    Upstate NY
    989
    7
    39
    Quote Originally Posted by Jraef View Post
    That makes sense. Given that the few things I need are working I think I am goingto move on
    Thanls for all the help
    Rick
  16. #16
    Oct 2004
    Iowa
    3,263
    86
    473
    I don't know the 160 product line at all, I'm a 1304/1336 guy (yeah, that much older), but... A-B was NOT shy about building 'for-customer'. I've found some of my legacy surplus units had special stuff, I found ways about it, either by figuring out, and changing my controls to work around it, or by replacing the non-ordinary criticals with workable others.
    I also found that an 'ordinary' drive would do 'different' things if an interface module or communication module were installed... so I usually remove unnecessary stuff.
