viper
Titanium
- May 18, 2007
- nowhereville
Targeting all you guys that setup VFDs everyday. I am swapping an older machine from a V/hz drive to a vector system. The VFD should run flawlessly for milling but some concerns are present regarding spindle orient and rigid tapping.
Spindle orient - Right now at tool change the machine is designed to slow the spindle to a very low speed, then command a very slow rpm and a shot pin is fired via air solenoid. When the shot pin falls in, a switch is tripped and the VFD is commanded to stop through the CNC control board. One concern is with the new vector system, there might be sufficient torque still at low speed that if the switch is not fast enough, it could push through the pin stop and damage it before the VFD is given the command to stop. Probably no way to tell until tried.
Obviously the shot pin arrangement is NOT ideal in any case. This VFD is equipped with the encoder feedback card as well so orient via encoder positioning is an option. The later machines do this but the encoder position is parameter set in the control. With this machine software not able to do that, I would just have to rig something to fire or close that home switch when the position is found by the VFD itself BUT the control would respond with a VFD stop command that would probably terminate the orient hold. I would also have to find a way to send a voltage signal to the VFD to command orientation.
There is likely not an easy way to add an encoder as of now because the motor snout is direct mounted in a transmission so getting 1:1 speed to the encoder might be a challenge. Also because of the retrofit, I would like to see if things work as designed before going through the trouble and would run in sensorless mode.
I am curious if the shot pin system sounds like a BIG issue or something I can work around with parameter settings?
Rigid tapping - The way this machine taps is it uses an encoder feedback from the spindle to the control board. The control board commands a speed to the VFD but ultimately just watches the spindle speed and adds Z axis feed to match it according to programming. I am just wondering if there is anything thing I need to worry about here? Specifically decelerations and stops? I can only assume that the control can react with lightening speed to spindle speed changes to make this pretty seamless but I am little worried that the tighter speed control might make the deceleration faster and something that the control is not used to accounting for.
