Another motor wiring mystery
Likes Likes:  0
Results 1 to 7 of 7
    Aug 2007
    GA
    674
    118
    Default Another motor wiring mystery
    Got a new looking delta 33-830 radial arm saw the other day, a basket case. The motor on this machine is dual voltage single phase capacitor start, and had a switch on it under a cover to change voltage from 120 to 240. It came to me minus the switch, and with some not OEM wire nuts on some of the motor wires, and 2 black wires hanging in the wind- one from the motor and one from the centrifugal switch. Does not run, with or without the 2 black wires connected. Windings LOOK fine. motor has SEVEN wires...owners manual does not have a wiring diagram. Delta customer service doesn't either. Neither does Emerson (LISTED as the motor mfg) or Nidec, who contracted from Emerson, or US motors who actually MADE it (!!!) and this is not an old saw... In any case here is what I have to work with:
    img_20190818_185809.jpg any ideas? I'm making a chart of resistance readings between wires to try and make some sense of this thing. 8 wires would make a lot mores sense to me though and there are 2 yellow wires...
    Aug 2014
    bainbridge island
    1,130
    215
    267
    is that a start capacitor or a run capacitor and what is the uf and voltage rating?
    Aug 2007
    GA
    674
    118
    30uf 370v, metal case. I THINK it's a start cap because it's wired to the centrifugal switch, but I don't know if it's wired right as it sits.
    Aug 2014
    bainbridge island
    1,130
    215
    267
    That would be a run capacitor. Its possible the start switch shorts out the capacitor for starting, but personally i have not yet found a motor that does that,
    7 wires oit of the stator is odd. If it is a dual voltage non reversible motor then it could have 5 wires from the stator and two from a thermal circuit breaker.
    Aug 2007
    GA
    674
    118
    The thermal unit is self contained & in contact with the windings but removable so none of the wires coming out of the stator are from that...
    Aug 2014
    bainbridge island
    1,130
    215
    267
    7 wires could be from a tapped start winding. Part of it is permanently connected to the run cap, the other part gets the full line voltage through the start switch, but only briefly.
    Sep 2004
    Alabama
    565
    91
    Contact some of the folks at vintagemachinery.org that own those saws and see if anyone will help you.
