I am new to this forum and there seems to be a lot of knowledge.
I have a single phase 110 volt motor. It is on an Old South Bend lathe. Someone twisted the wires together and ran it that way. In the reversing switch they cut wires so it only ran in forward. I picked up a new reversing switch and I found a problem. It does not work right. I can follow a wiring diagram and am quite good with electricity. I am thinking maybe a motor problem, that is why it was hacked previously. 3 of the 4 wires are still marked. So that helps. And they seem to match the pairs for the windings.
OK.... The motor is 110 volt, single phase, 4 wire, Guessing capacitor start because it has a capacitor hump.... It was designed as reversible (4 wire) 2 wires to one leg... the other 2 wires to the other leg. Runs fine. You are supposed to reverse one winding, either winding, and it should throw the motor in reverse. I reverse the wires and once I got a hum with no rotation and the other times tripped 20 amp breaker instantly. Trying different combinations. There is only one combination that works and that is in forward. The original way it was hooked up when I got it.
I made sure the 2 windings were isolated. They are isolated from the other winding, and both are isolated from the chassis (ground). Both windings are approx .6 ohms. The only thing I can come up with is MAYBE a bad capacitor????
Scratching my head on this. Any ideas??? I could understand a shorted winding... But why does it run forward fine??
Figure 3 should be close to what I have. It is a 3 pole, double throw switch. Ran horizontally in the picture.
This picture is a type KG motor... I think mine is a KC. But I can't find any internal wiring for it. I am not sure where the relay should be even if there is one still there. Being almost 80 years old, who knows how many hands it has gone through.
Any ideas where to go next?
