Hi everybody,
I'm looking at an Invertek 200-240V single phase input drive. [ODE-3-220105-1F42]
I'm to figure out if it will take a P-07 Value less than 200 Volts to match the weirdo 115 3-Phase motor on my Super 11 lathe. This is the one i was talking about in another thread here.
The drive manual's P-07 setting says "For Induction Motors, this parameter should be set to the rated (nameplate) voltage of the motor (Volts)."
Can somebody help me verify that the drive will accept lower values than 200V? Specifically, can you try setting it to somewhere less than 120V and see if it takes it?
I was going to let the voltage overrun and just limit the current but in testing, I've found it really doesn't like voltage in excess of the name plate (115V). More on that later.
Also, what P-51 Motor Control mode do you run yours in when using a lathe? I'm confused by the various control modes [i.e. Vector speed control, V/f, PM motor vector speed control, Synchronous Reluctance and LSPM motor vector speed control]. I was looking for a description but can't find it on the Invertek site or in the manual. (not obvious for a noob :-).
Thanks a lot,
-Dave
Thanks a lot,
-Dave
