Arboga G2508 Drillpress, Run with VFD?
Likes Likes:  0
Results 1 to 4 of 4
    Mar 2020
    SWEDEN
    Default Arboga G2508 Drillpress, Run with VFD?
    Hello!
    I just bought a G2508 two-speed arboga drillpress. i have a VFD ABB ACS50-01E-02A2-2 ABB -; ACS50-01E-02A2-2
    Is it possible to wire this to my Arboga in a way that doesnt alter the power to much through my VFD?. I read about only using the second speed of the engine?
    I am not good at electrics..
    /Johan Sweden.
    Apr 2010
    Surrey, England
    371
    1068
    74
    Looking at the lathes.co.uk page on the Arboga, the motor is 400v only (it's a Dahlander-wound 2-speed) and that ABB drive is 230v so you'll lose most of the motor power and torque.
    230 to 400v inverters are getting less expensive, or a 400v input VFD *can* be modified to fool it into thinking it has 400v in - I do this for my lathe (also has a 400v-only Dahlander motor, 3-speed, would be more money to have it rewound than the lathe cost me) but it can shorten the life of the VFD capacitors and the VFD needs to be a size or three bigger than the motor rating.
    If you use the low-speed winding you get more torque, increasing the VFD Hz will give you the full speed when you want it (I've never had a drill run out of RPM, had many run out of torque!)
    Dave H. (the other one)
    Apr 2010
    Surrey, England
    371
    1068
    74
    I dug a bit further into lathes.co.uk, the motor in the Arboga is 1 HP (750 watt) at 400v, that VFD is max 1/2 HP, so wouldn't be big enough anyway - if you hack a 400v or buy a 230-400v be sure it's rated for more than an HP (1 kw would be a good starting point)
    Mar 2020
    SWEDEN
    Thanks!
    So what branch would you choose to get it running ?
    230v to 400v inverter, is this equipment capable of running it with same power/torque delivery as 3-phase?
