superman22x
- Nov 5, 2017
Looking for some tips on my VFD. I am setting up my Teco L510 to use with my new to me Wells Index 856 mill. Currently, everything is wired up, and works normally using the 3 position switch that is originally installed on the Wells Index Machine. And I wired in an external pot for speed control. I have two questions though:
1) If I set the max freq above 60, I get an error. I have read some people recommend setting the max to about 75 for older motors, to run them a little faster, giving more speed range at one belt speed. Is there a way to do this with the Teco VFDs?
2) I'm trying to do a little power tapping with my mill. I have a Jog Fwd/Rev switch wired in. I'm wondering if toggling this is the way to go for tapping, or if there is a better configuration to wire in?
Thanks!
EDIT: Added a picture of said mill. I haven't seen this model before getting it myself. It's had many years of use at a University, but it works great for me.
EDIT 2: One more question... this mill has a power feed that runs off a 0.25hp motor. I hooked this up to a static phase converter, so I'm down to 0.17hp. The problem is, this motor gets very hot when it runs for a relatively short time. I'm not sure if this is due to it being low on power now, or just beyond it's usable life. Has anyone fit a modern servo style feed on these Wells Index machines, and how difficult is it to fit up?
Thanks!
