Hackshopridge
- Jun 22, 2021
I recently acquired Bridgeport series 1 mill and picked up a Automation direct gs2-22P0 VFD to power the machine. I wired it up and ran a dedicated 220v 20 amp circuit for it. Upon pressing the run button I get a ou fault code. I will post pictures of the wiring and motor nameplate below. Fault description per the manual states that the AC drive detects that hte DC bus voltage has exceeded its maximum allowable value.
- Now with that being said I check the power coming in across L1 & L2 and was getting a consistent 240v with a multimeter and also increased the decel time in the parameters setting from the default 5.00.
- Double checked the motor for correct low voltage wiring configuration
- The motor sounds like its trying to kick over after pressing the run button but immediately faults out to the ou code.
Any ideas of what could be causing this?
