Band saw tripping overload
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Sep 2013
    misssissippi
    31
    Default Band saw tripping overload
    I recently purchased a Kalamazoo h9wa, 2 hp 3 phase. It runs good but after a few minutes it trips overload on contractors. I am running with a phase converter which is plenty large enough. Voltage is 120 on 2 legs and 230 to ground on the stinger leg. Amps while running is 8amps on the two 120 legs. And 2amps on the stinger. Is this too much? Could the overloads be weak? I did check resistance between l1,l2,l3 it was 2.5 and none to ground. I don’t know what else to check any help would be appreciated!
    Aug 2005
    Kingsport, TN
    1,269
    5
    72
    3 phase VOLTAGE measurements should be made Phase to Phase. Phase to ground tells very little
    The low amps on your generated leg is not normal.
    State the amp rating of your starter heaters also. They may be undersise.
    Bruce
    Sep 2013
    misssissippi
    31
    L1-L3 275v
    L2-L3 257v
    L1-L2 240v
    Max 20 amp on overload. Dial has 4-6
    The low amp was not on stinger leg as previous stated
    Jul 2009
    Peoria, IL
    11,712
    51
    8968
    My chart says full load amps on a 2hp motor is 5.6A. So, your heater is properly sized, depending on the service factor.
    If it's pulling 8 amps on any leg then something is wrong.
    Jun 2013
    Northern Il
    1,284
    673
    1216
    Is this a static phase converter?
    Your currents sort of make me think that the motor is two phasing under load which might mean that it is the phase converter.
    Sep 2013
    misssissippi
    31
    Quote Originally Posted by Ziggy2 View Post
    No, it’s a American Rotophase 25hp
    Aug 2004
    2,700
    25
    618
    Something's still wrong. 8A on two legs is why your OL relay is tripping. DON'T BLAME THE OL RELAY, it's doing its job of preventing a fire in the motor!
    Jul 2014
    MI USA
    884
    197
    367
    My thoughts are you have 2 issues going on here, contributing to the problem.
    First is the RPC size. Most converters have a minimum size load motor you can run without overheating it. This is due to the amount of capacitance provided in the unit, being sized for the maximum converter load. With too much capacitance for a small motor, the voltage being produced will be high, driving the load motor magnetics into saturation. Saturation and high voltage, causes excessive currents.
    Your highest voltage was stated at 275V. This should be around 260V maximum with the small load connected. The phases with the highest voltages will be the ones with the highest currents. The converter needs to be re-tuned for a smaller motor if you want to get the output voltages in line.
    Second is the overload relay. As stated earlier, the motor is pulling over its rating, causing a trip. Helping to facilitate that trip quicker is the overload type. IEC type adjustable overloads normally have built in differential protection, to guard against single phasing. This means that when the current between lines is unequal, it causes the relay to trip faster than it would with a balanced overload.
    Bottom line is you need to balance the output of the large RPC, in order to be able to run a small motor successfully, without killing it and the overload relay.
    SAF Ω
    Sep 2013
    misssissippi
    31
    Quote Originally Posted by SAF View Post
    SAF Ω
    Thanks for all help. This is the first small motor I have ran with overload protection. (which found my problem maybe) I did notice when I was running multiple machines it dropped the amps a little bit and ran longer before tripping. I have a 5hp on my lathe with reversing contactors, the motor was rated at 200v so I put a buck/boost transformer to take care of the voltage.
    Could balancing the voltage of the RCP be as easy as unhooking some of the run capacitors, until I get desired voltage?
    Apr 2005
    Beaverdam, Virginia
    7,342
    639
    3456
    Quote Originally Posted by jaddy View Post
    Yes and no. Problem is what it takes to balance a simple rotary will vary depending on what loads it is running. I would not balance a 25hp rotary using 2hp as a test load. It does seem odd that your bandsaw is being feed with high voltage and pulling high amps, high voltage should lower the amperage. Have you tested the motor for issues?
  11. #11
    Sep 2013
    misssissippi
    31
    I did an ohms test to each leg which read 2.5 and to ground from each leg which was OL
  12. #12
    Mar 2009
    Eureka, CA
    3,721
    734
    1271
    This may have been covered and I missed it. Have you pulled the blade and looked for or considered a mechanical issues? The motor may be working hard because you have a worn out gearbox or a binding band-wheel or guide block.
    Stuart
  13. #13
    Apr 2005
    Beaverdam, Virginia
    7,342
    639
    3456
    Was your voltage from inside the motor cover or taken at the converter or incoming breaker or switch on the saw? If that voltage is what is inside the motor cover look for an excessive load due to mechanical problem as stated above. It seems the motor is probably okay.
  14. #14
    Jul 2014
    MI USA
    884
    197
    367
    A test that you can do is to connect the saw to the output of your buck transformer. If the overcurrent is due to the high voltage, it should be somewhat reduced on the lower voltage feed. Maybe still not perfectly balanced but better.
    Have a read on this document for balancing procedure of a RPC.
    http://www.practicalmachinist.com/FitchWConverter.pdf
    SAF Ω
  15. #15
    Sep 2013
    misssissippi
    31
    I tested another motor in shop. A 5hp 2 of the legs has 15 amps and one has 0. So the phase converter must be a fault.
  16. #16
    Sep 2013
    misssissippi
    31
    I inspected Rpc cabinet there is 12 100ul run capacitors. They have been leaking, it’s hard to tell which one. Think my next step will be taking each out and testing them.
  17. #17
    Apr 2005
    Beaverdam, Virginia
    7,342
    639
    3456
    I have found leaking capacitors that were working just fine. Didn't you say the output on the RPC was good? Maybe I misunderstood. Honestly a basic AC 3 phase motor on a manual machine should me able to run on an unbalanced RPC. I have a rotary RPC that sends out all kinds of high unbalanced votages running all my manual equipment and have not had an issue in over 20 years. I would just remove the run caps, measure the voltages and try the bandsaw again. My guess is you have a bad connection somewhere. Please let us know what finally fixes the problem.
  18. #18
    Mar 2013
    Cerritos, CA
    386
    129
    146
    Quote Originally Posted by atomarc View Post
    Stuart
    I agree with Stuart, I’m not saying it’s mechanical but it deserves a check. I had a similar issue and checked everything electrical before I discovered it was a simple mechanical problem
  19. #19
    Sep 2013
    misssissippi
    31
    Quote Originally Posted by Lanso View Post
    I have check that, it turns free by hand. I would think that was an issue.
  20. #20
    Sep 2013
    misssissippi
    31
    Quote Originally Posted by Dualkit View Post
    In process of checking. One thing I did try something that was cut all equipment on at same time which was 2(5HP) 1(1hp) 1(1.5hp) 1(2hp). I checked my voltage output for RPC and it was pretty close to the same. And the saw didnt trip the overload. So i'm studying on how to balance the voltage (i think its my problem) its not common to run all at once.
    The reason for large RPC is i paid $300 for it, replace the switch that kicks start up caps out, has been working pretty good.
  21. Likes SAF liked this post
