Belle large 1 ph motors---- anyone use one?
Results 1 to 11 of 11
    May 2019
    Michigan
    1,568
    457
    773
    Default Belle large 1 ph motors---- anyone use one?
    Belle Motors is selling this motor/starter package from 30 to 100 hp that runs on single phase.
    Does anyone here have any experience using one of them?
    I am thinking about using a 40 hp for a hydraulic power unit instead of using a phase converter.
    Not spam, BTW....
    Aug 2012
    California, Central Coast
    4,441
    2287
    1776
    Havn't used one but I did talk to them about their single to three phase generator run off the big 1ph motors. 30 hp motor was around $10k IIRC.
    Sales guy did mention electronics and capacitors to get it started. Could those be an added failure point?
    Aug 2004
    2,753
    27
    663
    What they are using is called a "Written Pole" motor design. In a nutshell, the rotor has permanent magnets and as such, "creates" the 3rd phase, then uses it. These motors are VERY expensive and once you go that route, you don't have an "off-the-shelf" motor that can be replaced in a hurry. But if that's not a problem for you, then the technology itself works well.
    Details if interested.
    https://pdhonline.com/courses/e299/e299content.pdf
  4. Likes Rob F., fusker liked this post
    May 2019
    Michigan
    1,568
    457
    773
    Quote Originally Posted by Rob F. View Post
    .....30 hp motor was around $10k IIRC.
    Wow, I could get a Phase Perfect and a 3 phase motor for that kind of money.
    Aug 2012
    4,441
    2287
    1776
    Quote Originally Posted by ChipSplitter View Post
    With the genny head attached was closer to $15k, but it might not burn out all the electronics in you house when it fails, like wheeliekings phase perfect....
    Dec 2019
    NEW ZEALAND
    132
    28
    Interesting that they're commenting on the low starting current, long start times, low starting torque, and high power factor and efficiency. Apart from being synchronous, it sounds an awful lot like a permanent split motor.
    Oct 2005
    17,884
    Quote Originally Posted by Jraef View Post
    Instead of permanent magnets, why not just a externally excited field ?
  9. #8
    Jul 2007
    Missoula Mt
    370
    10
    140
    Then it would be a synchronous motor, with a split field for starting...A good Idea...Phil
  10. #9
    Aug 2014
    bainbridge island
    1,257
    261
    297
    Quote Originally Posted by Phil in Montana View Post
    but no way could you get the starting current down to just 1.8 times the full load running amps, while providing 112% full load starting torque.. which sounds like that torque is flat all the way up to pull in speed which is why this motor takes triple digit seconds to start up in stead of double or single digits...
  11. #10
    May 2019
    Michigan
    1,568
    457
    773
    I'll admit you guys are kinda going over my head.
    I'm used to making chips, not move electrons from point A to B.
    What's a synchronous motor, pray tell?
  12. #11
    Dec 2019
    NEW ZEALAND
    132
    28
    Synchronous = runs at exactly the supply frequency, or a divisor thereof. So a 2-pole motor on 60Hz runs at 3600RPM, 4-pole at 1800RPM. These tend to have issues getting up to speed - sometimes started unloaded and spun up by another motor. Generally only either very large or very small. Used to be used for clocks.
    Asynchronous = runs at less than the supply frequency, generally refers to induction motors. So a two pole might run at say 3450RPM.
    Then you have DC motors and their cousins, the universal motors, which spin at a speed unrelated to the supply frequency.
