Best voltage output for a vmc when output from transformer taps are either low/high
Likes Likes:  0
Results 1 to 2 of 2
    Oct 2006
    Petaluma CA 94952
    594
    97
    Default Best voltage output for a vmc when output from transformer taps are either low/high
    Installing a DMG DMU103V euro vmc nominal voltage is 400. I have a delta to wye 230-400volt transformer. Ground is bonded to X0 on output side. Ive got 240 here with a hot leg. Im seeing 436 volts on the 400 volt taps and 386 volts on the 360 taps. Internal transformers for accessory voltages can be set to 380, 400, or 440. Is it better to go under voltage or over voltage?
    At the previous location the transformer was wired to a 240 service the same as mine, it was wired using the 400 volt taps.
    Jul 2014
    MI USA
    983
    205
    404
    Can you post a photo of the transformer tag? Normally adjustment taps are on the input side.
    Is yours a reverse connected unit?
    If so the taps will operate in reverse.
    What is your input measuring leg to leg?
    SAF
