its a very old bridgeport with pancake motor, and an old sb hvy 10 lathe. probably 3/4 hp, maybe 1hp max. both voltages are available on site but obviously using a regular 120v plug in power cord would be easiest...
... through electrickery ...
Many (if not most) 15A receptacle circuits are wired with 14ga wire and a 15A breaker.
Just so that you know (and for the benefit of future readers contemplating the same issue):
The 120V and 230V drives are identical, except for the fact that the 120V version has an ADDITIONAL set of components called a "voltage doubler" on the input side. T.........
Usually you need a second bulk storage capacitor, as they charge one cap on the positive cycle, the other on the negative cycle, and put them in series. But many drives probably use multiple caps anyway.
Old computer power supplies just had a switch that added or removed the link that changed it from a straight bridge rectifier to a voltage doubler.
Notice
