Breaker size for 10 hp RPC?
Results 1 to 8 of 8
    Jan 2018
    South Carolina
    185
    83
    Default Breaker size for 10 hp RPC?
    I recently picked up a 10 hp motor to make an RPC. It runs smoothly on 1 ph if I spin it up, and works on a 40A 240V breaker. I plan to buy a control panel for it so it will start and run reasonably well balanced. The question is- What sized breaker for light use? My mill and surface grinder are only 1 hp. I do have a 3 hp 3ph motor I might put in a belt sander. Will these run (one at a time) on the 40A breaker? I know the 10 hp RPC is overkill for my application, but I would like to get a bigger lathe someday.
    Jul 2008
    Philadelphia
    1,942
    514
    445
    Why not contact the manf. of your RPC. They should be able to tell you right quick.
    Jul 2004
    Houston, TX USA
    29,632
    Quote Originally Posted by MushCreek View Post
    "Spin it up" takes less amps than the proposed panel's cap start. You could try the forty and see how it does. My 15 cap start uses a pair of 50 amp slow blow fuses in a disconnect with never any issues. This is with 6 AWG about 6 feet long
    Feb 2008
    southern il
    875
    147
    296
    IIRC, my panel called for minimum 30 amp and max 50 breaker, for 10hp setup.
    Jun 2009
    Michigan, USA
    2,180
    3305
    1718
    I have a 10 Hp RPC dedicated to running a VMC with a 7.5 Hp spindle motor and I have a double 30 amp breaker on it. Never had any problem with it.
    Dec 2008
    IL/WI border
    3,207
    1015
    933
    40A breaker will work fine with your future 5hp lathe even if you run it along with all your present machines.
    Just for a perspective...I use my 15HP on a 60A breaker, and my 7.5HP lathe and 1.5HP Bridgeport with spindles rotating, when work simultaneously, draw only 32A off the 1ph RPC input. The RPC idling alone draws 10A (with 90A starting spike).
    My old Ronk 10 RPC suggested up to 50A breaker.
  7. Likes Hopefuldave liked this post
    Mar 2009
    4,972
    89
    910
    Have used a 20A breaker with a 5Hp rpc for years.
  9. #8
    Jan 2018
    South Carolina
    185
    83
    My American Rotary panel arrived yesterday, and I'm impressed with the build quality. I'm going to install it right next to my 1ph panel, with a 50A breaker and #6 wire connecting it. For now, I'm going to put a 30A 3 ph rail mount breaker inside the RPC panel, and run a single 3 ph outlet to run my mill. Eventually, I'll wire up a separate 3 ph panel, but I don't need it for now.
