I am getting ready to upgrade the wiring on my new to me Bridgeport mill. I am powering the mill with my rotary phase converter. The way the mill is currently wired power goes to a main disconnect(no fuses or overloads) and then branches off to separate switches on the back of the column that have overload protection built into them for the head, coolant pump, and the power feed for the table. Power goes from those switches to each respective motor on the machine. The head and power feed each have an additional switch for off, forward, reverse.
The overload protection in the switches only monitors and switches two of the three phases. The third leg is not switched or monitored for load which leads me to belive that this mill was probably originally fed from a corner grounded delta supply which I don't have. Because the head and the power feed for the table have separate switches on them I would like to eliminate the switches that have the overload since they are redundant from a switching standpoint and old and replace them with just some form of overload protection. The head is 1 hp, the coolant pump is 1/4 hp, and the power feed is 1/8 hp. The loads from these motors are so small that my search for overload relays that do not have contactors has given few results. I am tempted to use three pole fuse blocks with time delay fuses for each of the motors in a cabinet on the mill. Is there a different option that I am missing? I don't like not having the third phase monitored for overload. Am I over thinking this?
Thanks!
Thanks!
