I just obtained a milling machine and was wondering about the best way(cost wise) to power it. The machine itself is a Vilh. Pedersen horizontal that has been modified to accept a Bridgeport style head on the overarm, giving it both a horizontal and vertical spindle. Vertical spindle is run by
a 5hp 3phase motor 220 volt 4 pole motor. It is controlled through a vfd and runs the spindle and power feed for the quill. Horizontal spindle and table feeds are run by a 4 hp 3 phase 1720 rpm 208 volt motor. This machine ran well on three phase power, which I do not have.The simple solution would be to get a 20 hp phase converter and be done with it, but $2500+ for a new one is a little pricey for me, and im not confident in building one myself.Can I just get another vfd for the 4 hp motor, or does anyone have other suggestions? thank you
