Brook Crompton single phase motor damage
Likes Likes:  0
Results 1 to 8 of 8
    Apr 2020
    UNITED KINGDOM
    Default Brook Crompton single phase motor damage
    This is my first post in this forum so first of all, hi everyone! I would appreciate your help in repairing the Brook Crompton single phase motor from a Fobco Star pillar drill which has been given to me recently. As you can see in the photo, the thin metal ‘plate’ with white half-cylindrical plastic part was damaged. One side is terminated with a yellow wire, which then goes to the 'AZ' termination stud, on the other side, a yellow wire from the winding was connected with push-on crimp terminal. What is the purpose and principle of operation of this metal ‘plate’ (also, what’s the correct wording)? How can I fix it because I’m guessing that there is no chance to buy such a part anywhere?
    Mar 2011
    Geneva Illinois USA
    6,439
    2817
    2521
    That is part of the motor starting circuit. The end opposite the wire once had a electrical contact that made a circuit with the bottom part in the second photo. This applied power to the start circuit to get the motor going, then when it is near full speed, that contact is opened.
    I would take the motor to a motor repair shop that may be able to replace it, but more than likely you will have to replace the motor.
    Tom
    May 2015
    UNITED KINGDOM
    1,283
    389
    365
    As Tom says above I think your best bet is to place the motor. As Brook Crompton is very common in the UK you shouldn't struggle too much.
    Consider putting an advert on "Home Workshop". You may well be very surprised
    John
    Dec 2019
    NEW ZEALAND
    129
    27
    You might also be able to use a potential relay to disconnect the start winding instead of the centrifugal switch. Just bypass the switch.
    This only works with a cap start motor; if it is split phase (resistance difference between windings), you would need to use a current-operated version.
    Mar 2009
    5,602
    103
    1084
    It looks to me like the mounting position on the phenolic board broke off. If that was my motor I would cut out a new phenolic piece and remount all the parts again.
    It can be done if you have the time.
    Apr 2020
    UNITED KINGDOM
    Thanks for the answers, normally I'd take it somewhere to repair it properly, but in the current situation (lockdown) everything is closed. John, do you mean putting an advert to find someone to repair??
    SomeoneSomewhere, this is not a cap start motor, could you give me a hint how could I use a relay (with timer)?
    Rons, yes, it is the part of phenolic board broken, unfortunately, a copper / metal strip is damaged as well so probably the entire part needs replacing
    Do you guys think this can be solved by using an external relay? If so, can you please direct me a little bit?
    Dec 2019
    NEW ZEALAND
    129
    27
    You would be looking at a 'Current (sensitive) starting relay'. We'd need nameplate details to be able to actually say which one. The relay coil is in series with the motor run winding, and closes the contacts for the start winding when the run winding is drawing more than about 2x rated current, opening them again when the motor is up to speed.
    An easier option is a 1-2 second timer and contactor switching the start winding.
    May 2015
    UNITED KINGDOM
    1,283
    389
    365
    Quote Originally Posted by borntofight00 View Post
    Hi, no I don't mean that ... Put an advert on Homeworkshop asking if anyone has one of these motors (List type/spec and machine)
    I'm sure someone will answer your request bearing fruit
    John
