300sniper
Hot Rolled
- Nov 14, 2006
- Greenwood, Ca
I'm used to dealing with standard transformers that have lugs to land cables on. Now I am working with two 1.5kva (Acme T111684) buck boost transformers to buck my voltage. I am going to have #6 THHN coming in and #2 SOOW going out to the machine. The transformers have #10 and #14 pigtails. The small wire size still baffles me, but I suppose it is correct from what I've read.
Question is, what is a good connector to use for cable sizes so far apart? Obviously wire nuts aren't going to work like I see in all the videos.
Edit: I suppose split bolts would be the obvious answer, but since I started the thread, I'll listen to better options.
