I have recently got some VFD's, a 55kW Commander, a 45kW Commander, a 30kW Commander and a 30kW ABB.
All 380 to 480v. I have very little VFD installation experience. So with using a single phase isolation transformer to increase 240v to 415v. My motors range up to 5HP and the largest is 7 1/2 HP.
So would the general principal be to set the perameters to the combined motor load.
Just looking for ideas, is it doable, what is the down side. These VFD's cost me very little.
Jim
So basicallly... you are trying to apply a "big enough hammer" of small-enough-money cheap VFD ... to duplicate what a very EXPENSIVE "Phase Perfect" does as to serving as a general purpose shop-wide source of 3-Phase power for -
"bring any combination of loads you happen to feel like switching on"
.. any at given moment of any given day?
It has been done. It CAN work.. after a fashion.
It is an uphill battle.
The design philosophy of a VFD and Phase-Perfect are diametrically OPPOSITE to begin with. That matters. A lot.
- A VFD is a HIGHLY "dynamic" device. It is meant to be "tuned to", then serve a SINGLE load, knowing in advance that load will have highly varying needs - to which it must respond. Dynamically. VERY! "fast" in other words.
- A Phase-Perfect is the reverse. it is meant to stand fast as the local Rock of Gibralter regardless of what combination of loads are switched onto or off of its output or how hard those loads are working or how fast their loading is changing.
The "broad shoulders" it needs to JF DO that simply do not exist in a VFD.
-- Easily four times, if not ten times the physical space to house more than one set of much larger capacitors, HP for HP, to survive whilst taking the beating.
-- A HEAVY ration of multiple big, fat Iron and Copper INDUCTORS ... that a VFD has ZERO of.
I did say "uphill battle"?
FWIW-not-much? An RPC is "in between".
Not very "dynamic", it benefits from "some" run-cap tuning.
But is otherwise dependent on the Brute Force and Bloody Ignorance of broad shoulders derived from ...
ta da .. a large mass of.. Iron and Copper. "Rotating, even!"
Go figure an RPC JF works where a VFD tends to go bug-f**k nuts when operated out of its expected environment.
The controls get confused. And it has no "flywheel."
Compare by "gravity test". Weigh a 10 HP-capable VFD. Weigh a 10 HP Phase-Perfect.
Ski-boat. Container ship.
Pick any ONE!
