Degull
- Feb 3, 2014
- Toronto Canada
Hi everyone. I have acquired a Schaublin 150 lathe from the Canadian military. The lathe is setup to run 575V 60Hz and has 4 motors(Main spindle motor, lubrication motor, rapid feeds motor and cutting fluid motor). The total input power is 4.5KW as stamped on the outside of the power cabinet panel. I have 220V single phase in my shop.
4.5KW is approx. 6HP according to my calculations. The lathe is the only machine that requires a rotary phase converter. My other machines are running with VFDs.
What size rotory phase converter and idler motor should I be looking at?
