Randalthor
Cast Iron
- Mar 7, 2018
- Kansas City
I recently bought a new (used) work light for a B-port. It's a decent quality Halogen light. It runs off 24v. Takes a 70w bulb.
I have a 24v power supply in the same box I use for the VFD for the mill. I use the 24v power supply to run a small cooling fan for the box, to keep the VFD cool.
I'd like to use one 24v power supply to run both the cooling fan and the work light. My question is that when I look at DIN power supplies, they say something like "Single Output Power Supply". Is there any reason why I couldn't run both the fan and the light off one "Single Output Power Supply?"
I can't think there would be any reason why I couldn't run both off of one power supply (assuming the power supply is big enough - 120w would be big enough) but I thought I'd run it past some folks here.
I could just add another power supply, but the box is already a little crowded and I'd like to save some room in case I want to add something else in the box.
Also here are a couple power supplies I'm looking at, both 24v, 5A. Is one better than another for my application?
https://www.amazon.com/NDR-120-24-S...ly&qid=1550438326&s=industrial&sr=1-1-catcorr
https://www.amazon.com/MEAN-WELL-DR-120-24-DIN-Rail-Supply/dp/B07B3BF1RT
The cheaper power supply says it's for industrial applications, but I can't figure out the difference between the two, other than they look a little different and the price.
I don't know if it matters, but here are a couple pics of the box I'm using.
Here's the work light.
