ZK_SoTxArmament
- Oct 12, 2021
- Uvalde, Texas
I've searched the forum for a bit and haven't found any insight yet. I have a brand new Summit 14x40 Precision Lathe that is being powered by a North American RPC PL-10. The machine has power as everything seems to work minus the most important part; the spindle. It will not turn when the motor is in gear, forward-reverse lever is engaged and all safeties are disengaged. If I bypass the various safety connectors it still will not run. Yet when I push the override button on the connector for the clockwise or counter-clockwise spindle rotation, the spindle rotates just fine, but this is the only way it will rotate. Could this be caused by something as simple as the leads from the converter to the machine being connected in the wrong order? Or is this some other issue? Any insight would be very helpful.
